custom 6.0 up pipes
Cutting-Edge Diesel
Newkirk, OK
I can make up pipes for anything you want. You describe it to me and I will try to get as close as possible. stock flange, T3,T4 as well as other variations. PM for more details.
Pizza pig
MD
yeah buddy! Ill be in need shortly! Post up morgans t4 :pimp:
Cutting-Edge Diesel
Newkirk, OK
t4
stock
wastegate
another stock set
Pizza pig
MD
Matt will you do an open t3 flange or only divided? Also will you make them without bellows (solid)
Cutting-Edge Diesel
Newkirk, OK
I could do what ever you want man. T3 open wouldn't really matter because it would be divided with the pipes anyway if that makes since. Unless you wanted it to collect in to one pipe before the flange.
kyle43335
you honestly can only do a t-3 open.
theres just not enough room to divide to 2" pipes in that flange.
for a true divided turbine setup,one would need at least t-4
Pizza pig
MD
Thats why I was asking that T3's are tiny, Matt says is possible though ;)
Only gripe I have about doing a T3 is not being able to benefit from a larger diameter up pipe.
kyle43335
it would become the biggest restriction in the whole system. esp if hes crushing the pipe down.(like a formed pipe to fit in the flange)
i understand anything is possible,but why would you do it
i could have great sex with a aids infected female to
but i wouldn't!!! lol not hating,just saying
Pizza pig
MD
Its not really a restriction if youre merging them into a single/open flange. It could be better but its far better than the stock collector either way.
kyle43335
T3 open yes i agree.
T3 divded would be a problem.
Pizza pig
MD
Matt, do you happen to know what the smallest divided t4 housing is available?
