Custom Fabrication thread
Motostroker
I have searched high and low. And no dice. So I wanted to start this.
I have a certain project coming up and wanted I discuss various methods and materials used is custom fabrication such as up-pipes, turbo mounts, etc.
Don't get me wrong, there are company's that make great products, but this thread leans more towards the builder type guy. I want to ( from the ground up) build this project truck I'm purchasing. (More info on that later).
First question
- what material would you use for uppipes? Which bellows have you found that work the best?
- which type of welder would you recommend?
-considering building my own traction bars, which heim joint would you recommend? Preferably a H/D greasable, which tubing?
- truck will have a hood stack, best mounting techniques?
Sorry for so many questions, but i wanted everybody that has custom fabricated, chime in and share your do's/ and don'ts....
bigrpowr
<How I Fly
First question
for uppipes 321 stainless and the best tig welder you can get your hands on. thats all i got lol
bigrpowr
<How I Fly
Awesome! I'm thinking vibrant bellows. Not sure yet. I'm going to V band everything
i actually wrote 2 responses, the first got jumbled trying to reply to your quote line by line.. yeah im pretty sure the vibrant bellows are your first choice.
Powerstroked162
On Da Juice
Wa. State
Vibrant for your bellows for sure. Make sure you get the interlocking mesh bellow rated for 100psi. Those things can take a beating.
As far as traction bars go, I wouldn't recommend any heim joint. I'd use a ford radius arm busing up front and a shackle in the rear. Similar to what Dustin did on Oprah. Heims always wear out and can be noisey.
40wt pipe will always hold up but I honestly think 20wt would suffice plenty if the bars are setup right and in the right diameter.
Hood stack, I say fender stack :D
Dzchey21
wyoming
like steve said, i prefer using a radius arm bushing instead of a heim, you might use a ballistic joint or something similar on the axle end, my tubing is like 1.5 inch round .18 wall thickness, they worked fine, nothing special by any means
I always leave uppipes to people who have a engine on a stand, which i dont and usually when my cab is off im in a hurry lol
aluminum piping for the air charge pipes if you can do it.
