custom four link rear air suspension 99-07 f-250 f-350
PowerstrokeJunkie
Maryland
Listing my custom rear air suspension for sale. Been on my truck for maybe a year. Did not skimp on buying cheap parts- uses 2" x.250" wall Dom tubing for the links, johnny joint greasable joints, Goodyear 1r-079 rolling lobe air bags (semi type). Quarter inch plate used everywhere, and grade 8 hardware. Controlled by a set of Firestone ride-right switches ( manual control) set in a f-650 "manual" dash. Includes all the parts you need- front brackets, all links, panhard rod, bags, all air lines to connect to your existing air tank ( can sell separate if needed), dash panel, rear axle with u-joint scattershield. Axle currently has 146k on it, two year old Yukon 3.73s, a Detroit truetrac and mag hytec cover. Can sell with or without guts in the axle. Reason for selling- finding an increasing number of people turning away from buying the truck due to the custom suspension. This system is perfect for towing, rides smoother than stock without a load and rides amazing with a little tongue weight. I have towed over 25k lbs before and this system worked flawlessly. Not too sure on price yet. I think 2500 outright for everything sounds reasonable if I can keep the truetrac. Will work a trade for your stock axle and leaf springs and rear spring mounts. Located in central MD.
PowerstrokeJunkie
Maryland
suspension is the only thing for sale as of right now until it sells I will list anything that doesn't go with it Later. I'll get some pictures tomorrow hopefully I got a new phone lost all my pictures if you want you can search my username and look for friends that I have posted about it
Jake
TEXAS
I ran into the same issue on my 97. I want to build a set up for my 00. Good luck with the sale.
PowerstrokeJunkie
Maryland
Bump. Just pulled it off today. Need to clean it up then I'll get better pics
