Rob D
So I have searched all around the web on this problem.
2001 F350 ZF6. Truck does not have any loss of power, it does not shake or have any bad shudder etc., a very slight vibration at idle- my prior 03 7.3 felt the same way at idle. Truck does not smoke at all, and from what I can tell has never had a chip on it. This thing is a cream puff. Truck did have a 5er hitch so I am sure it did some work earlier on in it's life.
Before I bought the truck I had it gone over at the local shop. Buzz test was fine, contribution test was fine. Tech cleared the P0308 code and agreed truck did not appear to be missing at all. The SES light stayed off for about 100 miles, then SES came back on with same code. 180K on the clock.
From what I have read it comes down to either:
1 - Bad Injector
2 - Bad harness
3 - Bad CPS
4 - Bad fuel filter
Working from bottom up as those are easiest and cheapest to repair I have found that the upgraded CPS did not fix the problem. I did read auto vs manual has different parameters for what will throw the code if the CPS is slightly off (but could not find the thread again).
Checked the fuel filter this weekend and it was gross, definitely neglected. There was a decent amount of crud at the bottom of the bowl - I cleaned it all out. My concern is that if the main filter was this dirty, the tank is probably in lousy condition too. How often is it recommended to drop the tank and service the filters/socks in the tank? Also would it hurt anything to open the drain valve on the bowl with the truck running as a way to get as much fuel out of the tank as possible?
I have new filter on order, as well as upgraded regulator spring. I also read that removing the plunger/spring inside the tube that the filter goes over removes unnecessary restriction - obviously would never run the truck without a filter...hoping new filter and increasing pressure a bit with upgraded spring, if the #8 is starving from fuel a little bit this will fix it and maybe take care of the code?
Thanks in advance
Rob
1 - Bad Injector
2 - Bad harness
3 - Bad CPS
4 - Bad fuel filter
Thanks in advance
Rob
