SuperDuty73
- Joined
- Sep 14, 2012
- Messages
- 64
- Reaction score
- 0
If you wastegated the d66 would it be up to par for a compound setup?
I will be running 300/200s
Mark
Mark
38r is alot tougher turbo but anything can be done with the proper amount of gating..
The d66 uses a stronger bearing than just a normal van turbo or gtp38. They've proven it to hold to what a 38r is.
The D66 uses the SAME cartridge repair kit as a stock charger, the only modifications are to the CW, TW, and turbine housing. I wouldn't recommend using this as a HP charger in a twin kit unless you are ready to blow up both turbos and start over.
I wouldnt use a d66.....
