dana 60
zilla68
Moore Oklahoma
you know that's a good and funny question, because when I bought my dynatracs I called them first to ask about the camber bushings and they told they are not needed, but a couple alignment shops did say they could, so until I get to the shop I won't know if I need them or not I guess.
I did see them on moog's site I believe it was, but the alignment shop said they had them if I needed them.
kystroker7.3
Lexington,Ky
Well I must have them cause the balljoint has to go into the bushing because with out it there is too much slop around the balljoint
zilla68
Moore Oklahoma
yes that is correct, but my guess is they can change that out to get to the number they need to be at, if your at a legit alignment shop, I think most are cheap and only set the toe though, I was quoted 300 as a max to be done correctly.
mustube
Austin, Tx
The bushings change caster and or camber. Toe is set with tie rod ends. Any auto parts store should have them or be able to get them next day.
Sent from my XT1058 using Tapatalk
