Dash gage pegs water temp hot
08SUPERKING
The 08 f250 dash gage pegs to the hot and reduced eng power
Shows up. Truck not hot at all. Can the tstasts be sticking.
This the thrid time it does it but the second time in two days.
Do not know what actually fixed it but i disconnected the batteries
And the two plugs that go to the fire wall. Sometimes had to do it
Three times before it worked agian.
Any help or tips to solve this please.
:ford:
Heavyhaul
Wyoming
If its not really hot it could be a short to ground in the temp sensor wire or in the sensor itself. Im not sure by your post weather its really hot or not. If the t-stats were stuck closed it would overheat.
Rivets are the new duct tape.
08SUPERKING
How can i look for the short because the tstats are no stuck
Because it cold out side and truck has no been run and still
Doing the same.
08SUPERKING
Well truck started fin this morning but it has not been
Used all night. The two most resent times its done it has
Been after the truck was used then it will show the temp gage
Peg.
Athens, IL
Thermostats on these things have been known as problematic. But usually with over a 100k+ on the clock. I've replaced them alot. But if the engines for sure cold when it happens then it's probably wiring or sensor. I've had ones I that show pegged hot, then you shut off the key and turn if back on and they read.normal.
Sent while hooked to something, somewhere, with my foot through the floor!
tbsimmons
Bakersfield, CA
Mine started to act up just after 20,000 miles. It all depends on the radiators replaced, coolant level, truck ever got hot, etc. Mine just went bad for no reason.
Easy check is look at the EOT and ECT.
If they are not a consistent temp, as in they jump up and down, then the thermostats are bad.
08SUPERKING
Ok i will check that. Ford changed my t stasts maybe 15,000
Miles ago. My was right at half way. I added some to put it were
I normally keep it at.
08SUPERKING
Miles ago. My coolent was right at half way. I added some to put it were
08SUPERKING
Ok sct monitor showed temp @ 136 at first run.
Then parked the truck for three hours with 48* wheather
Out side and the next start up gage peged and showed 186*
On the sct monitor. Where would the temp senor be grounded
At. Or just a bad temp senor.
Dzchey21
wyoming
You need to check engine oil temp with Sct
The other guage on the dash is for Trans temp
08SUPERKING
Ok i will check. If i remeber right there was 60* between the
Two temps. Water 194 oil 134 that when the gage was peged.
With a warm truck sitting for three hours at 46* out side. And
The next start up it peged.
08SUPERKING
Ford said try the senor first if not to change the intrument cluster.
Can the clusters be rebuilt or can i find a used one to swap out.
I need the cheapest route to sold this promblem so i can get back
To work.
Thanks.
Dzchey21
wyoming
I doubt its the cluster. Oil and coolant temps should almost always be the same .
08SUPERKING
No codes.
Swap the temp senor or the oringinal one and it worked so far.
Do not know whats causing this but it getting to be a pain.
