Hey guys, just picked up a DD and I'm having a problem setting up one of the calculators.
I should start off by asking if what I'm trying to accomplish is possible. Trying to take EP (Exhaust Back Pressure- Absolute) and turn it into the "actual" number it is. Basically dont want to have to look at the EP number and subtract 14.7 to get the actual number.
So I downloaded the signal multiplier, and after inputting all the info I cant get my "actual" back pressure number to be correct, or even in the ball park of what it should be? Anyone have any ideas of what I'm doing wrong or things I can check? Thanks in advance
Input Signal: EP (Ford Specific)
Multiplier Signal: "Constant Multiplier" from the Signal Calculator column
Multiplier Sign: 1
Constant Multiplier: 1
Offset Signal: Baro (Ford Specific)
Offset Sign: -1
Constant Offset: 14.7
Multiplier Sign: 1
Offset Sign: -1
