20007.3stroker
How do you get the crush sleeve to crush? Had to put internals in my rearend and for the life of me I can not get it to crush to save my life.:shrug:
I didn't apply anywhere remotely close to that torque value while setting my preload. :shrug:Good luck, it takes 5-700 lbs of torque to get them to start collapsing. I normally use a 3/4" rachet with a 6 ft cheater pipe and a 36" pipe wrench to hold the yoke.
To the OP: Are you reassembling things in the right order? Don't forget the slinger that is in there. The bearing should sit in the race by itself without any preload. You should also be spinning the yoke as you tighten to make sure the bearings are seated properly as well.
You shouldn't be able to crush a crush sleeve with an impact gun. Get some good leverage on there (the 6' snipe isn't a bad plan...) and start cranking. Keep a super close eye on your pinion rotational torque numbers... you can go to far really easy, then you have to get another crush sleeve.
Once it starts to go, you don't have far to get the numbers right.
Well then I did the impossible. And it's been under my truck being beaten for a while now. To be honest I went past spec with it and had to replace the crush sleeve. All with an impact. :shrug: <-- that's a shrug. Can't see the arms. LOL
I don't know what you're doing.... but it ISN'T how crush sleeves work on the rest of planet earth...
What the guy is describing is EXACTLY how they act for everyone else. A new crush sleeve is VERY hard to get to start down. Once it starts, then it is as you describe. Now if you reuse one.... obviously you don't have this issue, and in a pinch, that can be done, although often times this just leads to the crush sleeve "floating" around and not doing a damn thing because the new bearings seat in the races and acheive pre-load before the sleeve does anything. Leaving the pre-load to fall off within a relatively short number of miles.
For the rest of the world.... the pipe wrench and 3/4 drive are the ticket. I usually take a pipe wrench with a pipe over the handle and run it down so the pipe digs into the ground under the pinion, then hold on to the leafspring or frame with my arms and use BOTH legs to legpress a 3/4" breaker bar until the crush sleeve starts down. Then I continue with one leg a little at a time, checking back and forth until the preload is acheived.
This whole nonsense like crush sleeves are easy to crush is just ridiculous. And using an impact? Equally ridiculous.
To the OP. No you're not crazy. And it sounds like you're right on track.
How are you checking pre-load?
With a Snap-On dial type torque wrench. :Edit I remember checking with a beam style torque wrench as well to see if they showed the same result. I accidentally tightened it the first time and made it so I could barely turn the pinion. That's with a new crush sleeve. So how could I go way past spec without crushing the sleeve?
I used an impact gun and just slowly impacted until I achieved desired spec. A little less physical labor. LOL
It wouldn't really make noise or come apart, it would just have noticeable backlash letting off and getting back on the power.
