We have been working on this idea for a while. This will be a DIY (do it yourself) upgrade. This will able us to offer great high quality parts that are still cost effective and price competitive. This kit is so easy to install, that if you can rebuild your turbo... then you can install this upgrade.
This idea came about because people often call us up and ask what we can do to fix their failed upgraded turbos that are operating poorly, surging, high egts, low boost, slow spool up, etc... These problems often come from poor quality machined housings that are cut by hand and eyeballed instead of using a precise computerized cnc program. This also happens from running a compressor wheel that is slightly too big for the turbine. We picked this size specifically to work in so many different applications.
Also we get calls from people looking to buy parts to build their own high quality turbos.
This upgrade will pair nicely with anything from stock to a stage 2 turbo. If you are looking for a nice upgrade to your stock turbo, or if you have a poor performing hybrid or stage 2 turbo then this is perfect for you. This will work with both 13 and 10 bladed turbines.
The kit will consist of everything needed to turn your turbo into a stage 1.5 turbo. This included a brand new CNC machined .72ar race compressor cover with backing plate, 63.5x88mm 11 bladed single plane billet compressor wheel, all hardware needed, and a complete rebuild kit including an upgraded 360 thrust bearing.
Here is a picture of what your new turbo will look like.
SO??? WHY .72ar stage 1.5???? Well it has a similar size compressor wheel as a typical powermax or stage 1 turbo... but it will be sporting a new .72ar racing cover. This will put it right in between the flow abilities of a a billet pmax/stage 1 turbo and a typical 64.7mm stage 2 turbo.
Price is $700 shipped
Please post any questions or send us an email at [email protected]
