DIY Head porting
jwlandry
S.W. Louisiana
What i want to know is can it be done in your at home shop? I dont see why it wouldnt. Im thinking of an end grinder with variable speed with a burr bit and to polish I was thinking some sanding stones.
How hard would it be to DIY? I know its time consuming, im not worried about that.
Thought, opinions, Discussion, & better ideas welcome...
neverkickn
AR
I don't think it's tooling that is the problem but rather knowing how much to remove and from where.
Whytry
Memphis IN
You can do it like that. When I got my head ported on my quad the guy who did it did it out of a small plastic shed lol. I don't remember exactly what he used though but it wasn't anything fancy.
young7.3
Southern Indiana
That could be one of the reasons you ran it into a tree.lol.in all seriousness I think you should try it on a junk head first.
swamp_ratt
hudson, wi
In all reality its about flow matching each port. You can do it, but will each flow the same? Not likely
Powerstroked162
On Da Juice
Wa. State
If you've never ported a head, understand that it is a lot more then just hogging out some material and smoothing out a few rough spots here and there.... You can really screw up flow and port swirl quickly without even knowing it.
I believe Suns_PSD is suffering from this issue with his head work
ITUKMOR
Smyrna, TN
the real worry on a 7.3L head is that removing too much material can get into areas of more porous metal. the swirling is not really that important as the application is forced induction and the fuel is injected directly into the cylinder. but if you do get into this "less dense" material it can allow moisture to seep through into the intake and exhaust runners. the valve guide area can cause shrouding due to the sharp edges and overhang. port size is important and I would recommend measuring them as you go until you have done a few. for tooling, several size and shaped carbide burrs seem to work the best with various sand rolls to smooth it all out. sanding stones did not work very good at all. another suggestion is to do all the intake ports at one time and the same with the exhaust. this way you kinda get a feel for what it looks like visually. this way you can get them all close and then measure them for the final touches. remember to go slow and check your work often. once you take off too much you can never put it back. happy porting!!
Powerstroked162
On Da Juice
Wa. State
the real worry on a 7.3L head is that removing too much material can get into areas of more porous metal. the swirling is not really that important as the application is forced induction and the fuel is injected directly into the cylinder. happy porting!!
Man, since port swirl and flow doesn't play any role of significance in a forced induction app, think of the $3500 i wasted in porting and head work that I could've done myself in my garage with a few carbides.... :doh:
How about this..... we take what you just said, re-do it using what I like to call "the right way" and see where we end up?
Just a little refresher:
There are different levels of swirl found in gasoline engines depending on whether it is a stock, mild or more wild application. On the flow bench you will often see that porting cylinder heads for more cfm causes the swirl percentage to drop. This happens because you are reshaping the port’s design for more airflow and most of the time the head porter is trying to straighten the port. Air tends to flow better with less bends and restrictions On a flow bench, swirl is measured with a swirl meter which will, in turn, be measured in rpm. In a typical small block Chevy, swirl ranges anywhere from 700 to 1,400 rpm, in accordance with how much lift is measured at the valve. This generally takes place from approximately .002˝ to .007˝ of valve lift.
Now in a diesel cylinder head, the swirl from the intake port entering the combustion chamber can be as much as three times the rpm of gasoline cylinder heads. Keep in mind that because the valve lift in diesel engines isn’t very high, we know the biggest differences will be that the diesel cylinder head is producing more swirl and doing it faster.
Why does this all really matter? Think of it this way, if swirl is helping to fill the ports of both the gasoline and diesel engines, why does the diesel demand more? In a gasoline engine, once the intake valve is closed and the swirling stops, the piston is starting to travel up the bore for the compression stroke. The mixture is just being compressed waiting to be ignited by the spark plug. In a diesel engine, when the intake valve closes and the piston starts the compression stroke, the swirling continues! Yes, as the piston travels further up the bore, the air continues to swirl faster and faster in the cylinder and the piston bowl. It not only moves in a circular motion, but also a spiraling motion. The reason for this is to light off the diesel fuel.
Remember, diesel is injected into the cylinder in very fine atomized droplets, an action that occurs at XXX degrees before top dead center. In a gasoline engine, on the compression stroke you have air and fuel being compressed in the cylinder. In a diesel, you just have air that is being compressed. So, when the piston is traveling up the bore in a diesel engine, cylinder pressure is increasing rapidly. When diesel fuel enters the combustion chamber, it has to light off. The more the pressure rises, the harder it is for the diesel fuel to ignite. Pressure tends to keep the diesel droplets in a suspended state. So, the swirling motion lets the diesel droplets that enter the cylinder cling to the bowl to aid in igniting the combustion
Most people think that port swirl in a diesel is used to aid in turbo lag. But actually, the turbo is used for the purposes of forced induction. This, in turn, puts more air in the cylinder. When swirl is taken away the power will go down.
jwlandry
S.W. Louisiana
This is what i was wanting... A good discussion about it.
Im not wanting to go all out on a port job but moreso just clean up the intake runners and exhaust ports. Just smooth em out really. Ill have an extra set of heads to get a feel of it first before i do it on my good heads.
jwlandry
S.W. Louisiana
As an Amazon Associate we earn from qualifying purchases.
powerstrokenstang
Verona VA
i screwed up a head doing it my self. its still a good head for some builds not mine as we didn want to use valve seats that could fall out and i knicked the seat area. i paid for a great port job that was matched on a bench. after hearing stories of spending 20 some hours porting only to get in to a water jacket it was worth the money to me to have a pro do it. plus the flow sheet looks great:cool:
jwlandry
S.W. Louisiana
If I do decide to do it, Im gonna try on an old set of heads first then do the good ones. All im really wanting to do is smooth out the intake runners and exhaust ports.
Powerstrokenstang, who did your port job?
