Powerstroked162
On Da Juice
Anybody here done anything with their dream beam 3/5 lowering kits? I have some questions
Good to know. Thanks. Next question is; what did you guys do for traction bars? I'm thinking my OUO's are gonna hang waaaaay low and might tear them up
If your running the power that you are talking about. I would check out the fabbing that was done on Ryan's (KIND) truck. He had total carnage on the rear with slicks. Basically, DJM does not use the stock sprig perch that is on the rear end. The equipment they sale is pretty good, but not rated for that much torque and it will not hold it. He just re-located his spring perches to the bottom of the axle. I am going to be doing this to mine when I get home. There is a link on CompD showing pics of the carnage and showing repairs. Hope this helps ya.
Yeah that's what I think I'm gonna be stuck with. I just don't like them
That wasn't a DJM kit. He had a flip kit that he destroyed. The DJM is not a flip kit and does not change how the axel is mounted to the springs. It is different hangers and a drop shackle.
Here's what they said they did to fix the problem
"All we did is order new spring purches which we will drill off set pins in and weld to the bottom of the axle (flipped).
Once done this afternoon I will post some pictures"
