Doing it Gangsta
jwlandry
S.W. Louisiana
I sent my heads to Doug at GoGo Diesel to get some work done to them and he has been working on some new parts for the 7.3 world. Here they are.
Stock is on left and the new ones are on the right.
Stock seat pressure is 72lbs and the new ones raise it to 175lbs
FWIW, comp 910s are 92lbs
Stock on left new on right installed in heads
Stock is on the right and the new ones are the left. These are the locks that keep the valve springs on the valve stem.
Stock on right new on left.
stock is 11/32'' New one are 7/16'' (aka Louisiville Sluggers)
FWIW most aftermarket ones are 3/8''
Enjoy and if anyone is interested in some get up with PTP and they can get you hooked up.
Austin
Parker, CO
I guess I'm somewhat uneducated on the subject, but at what point do the Comp springs become obsolete?
jwlandry
S.W. Louisiana
Just call eric at PTP and he can get you fixed up with the new springs and retainers as well as P rods if you need them. They are the only ones for the 7.3 that GoGo has so.
Gearhead
So it was your motor that Doug called me about at 2 AM this morning...... does he ever sleep?
