DPF Reinstall issues
jkidd_39
NW Arkansas
Gotta put my DPF back in for a trip to the dealer. Got 4 injectors coming up bad. Need Mr. FoMoCo to cover the bill.
I have the truck all swapped but cannot find the nipple that goes on the DPF and has the rubber hose connected to it.
What does this little sensor do and can I limp the truck 5 miles to the dealership without it installed on my DPF??
Thanks guys!
JDub
Hooper, Utah
That is the pressure sensor, it'll throw a code and limp without it. That sensor is expensive to get from Ford if it needs replaced.
Oregon
This is true! Very spendy lil unit.
Also found out if your not careful that plastic nipple connected to the actual sensor will break with ease.
jkidd_39
NW Arkansas
I have the sensor.. I just don't have the threaded nipple that goes in the actual DPF.. If someone knows the size and pitch i'm sure me and the fastenal store can make something
Twinturbostroker
El Paso, Tx
It is a pretty pricey lil "fitting" from the dealer, but cheaper than 4 injectors, that's for sure......may just want to spring for it
max2006
___________________________________________________
The nipple you are talking about feeds the pressure sensor. It's about $90 bucks from ford. It is special material to handle the 1200-1300 temp from regen.
jkidd_39
NW Arkansas
Got it fixed. 4 injectors under warranty. Used an air line fitting. Worked well enough. Now I gotta pull it all off. Fml!!
