DPF thread sizes?
Bosshawg600
Monticello,IN
So I just got my exhaust on and it came with bungs and unfortunately all my sensors were cut off, so I need to plug them up. Anyone know the sizes of all of them so I can just throw some plugs in them???
Stroked777
Casper, Wyoming
My exhaust came with bungs too, I didn't wanna break the sensors off so I dug thru my spare bolts bin, found ones that fit, tightened them down and cut them off with a cut off wheel flush
Big Angry Hillbilly
21432 2008-2010 F-SUPER DUTY EQUIPPED WITH 6.4L DIESEL- EGT SENSOR REMOVAL
EXHAUST GAS TEMPERATURE (EGT) SENSORS MAY BE DIFFICULT TO REMOVE FROM THE DIESEL PARTICULATE FILTER (DPF) ON 2008-2010 F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4 LITER DIESEL ENGINE. TO AVOID DAMAGING THE HEX ON THE THREADED EGT RETAINER, CUT THE WIRE JUST ABOVE THE SENSOR, APPLY HEAT TO THE SENSOR MOUNTING BOSS USING A OXYGEN/ACETYLENE TORCH, AND USE A 6 POINT DEEP WELL SOCKET WITH A BREAKER BAR TO LOOSEN. IF MOUNTING BOSS THREAD CLEANING IS NEEDED, A 12MM X 1.25 BOTTOMING TAP CAN BE USED. WHEN CLEANING THE THREADS WITH THE TAP USE CAUTION TO AVOID DAMAGING THE EGT SENSOR SEALING SURFACE LOCATED INSIDE THE MOUNTING BOSS.
EFFECTIVE DATE: 26-JULY-2010
Bosshawg600
Monticello,IN
Big Thanks!!! Just going to pick up some cheap plugs, Quick and simple!!!
