soo attempting to install some bellowed uppies and driver side pipe will not come out through the bottom or top, any suggestions? how far i can cut into the fire wall? thanks!
thanks cut a small bit from the firewall lucky no hole in cab got buddy to come help pull it. ended up going out the top which is strange would not go out the bottom....
Usually there is one magic spot where the downpipe slides out. I've done it three times and each time was difficult but the pipe always finally came out the bottom.
On the Red sig truck I massaged the firewall at the lower end of the up pipe area. Used a hydraulic jack against the motor mount iirc. Also bent over the complete pinch weld (full width of tranny tunnel) when I had the tranny out. Pipes come out easily after that.
turbo was out would not come up or down, i had a terrible time with my 3 inch downpipe before some reason my truck has no clearance behind the engine..... fuel pump turbo rebuild and up pipes + guages solid weekend wrenching lol not happy that the billet wheel i bought from supplier on another site would not even thread on my turbine shaft...
I have the same issue right now, my cab mounts are blown out, and it was the biggest PITA getting my downpipe in, i had to jack the body up as far as i could and actually dent the downpipe a little bit for it to slip into place. Going to be replacing the body mounts soon on mine.
