Texan6Seven
Has anyone had this experience? Installed a Fabtech drop pitman arm along with a Ready Lift track bar drop bracket this weekend and when I try to turn full left or right the pitman arm hits the track bar bracket. I’ve already verified that I have the correct part #s and made absolutely sure that the steering box was in the center of its travel when I installed everything. The track bar bracket is cast iron and I’m thinking I may be able to clearance the area where contact with the pitman arm is or should I just buy a fabricated track bar bracket from say PMF?
