Dropping the rear fuel tank in OBS.
cbuttre835
Ok so I have finally gathered parts for my bronco tank swap in my CCSB 97.
I dropped the spare tire and removed the two rear skid plate bolts. Very rusty, this truck is. :( Having to do a lot of sawzall work. Bottom of the tank is quite rusty on the outside. Hence my "water in fuel" and rusty fuel bowl woes...
I assume I need to remove the three screws holding the filler neck housing to the truck bed, to let that hose drop with the tank.
It got dark on me where I couldn't see well.
What about the wire and plumbing? What should I take loose before removing the two front bolts / nuts and letting the thing drop to the ground? Or is there enough slack in that assembly?
:doh::morons:
Oregon
Take off the return line, and then there is wiring plug up on the frame rail that you can unclip and your good to go.
But yes you need to undue the hose clamp closest to the tank and that hose will slide off. Sometimes you need to put a screwdriver or twist the hose to break it loose in order for the tank to drop.
Give us a call if you need any help.
mjonesjr
Salem, IN
Taking the bed off will be 100x easier, even now. Putting the tank back in with the bed off SUCKS.
cbuttre835
I thought about that, but truck has a topper and the bed is rhino-lined. Don't know how I'd dig that crap out of the bed bolts.
fatsix
South Jersey
uhm, the nuts are on the bottom. The rhino lining might help the bolts from spinning if the square hole rounds out.. Think carriage bolt. Might have an issue putting the bed back on and not getting the holes lined up before dropping the bed on. Could push the heads through the rhino lining.
cbuttre835
Aha. I thought they had a torx head on em. Didn't realize they were carriage bolts. That changes things... :doh:
cbuttre835
Taking the bed off will be 100x easier, even now. Putting the tank back in with the bed on SUCKS.
This is true. I damaged the factory lines and just can-not get them reconnected... aaargh!
Anyone make a kit to lenghten or otherwise replace the factory lines? About to cut the factory rubber crimped ones off where the stainless ends and use 3/8 fuel line.
FrankTheTank
Cecil County, MD
Agree with taking the bed off. Its only 6 bolts, an electrical plug, and 2 filler necks. My bed too was rhino lined and the bolts were covered. They all stayed in place and didn't move.
cbuttre835
I gave up on taking the bed off, due to the camper shell and extreme rust on the nuts on the bottom of the bed bolts.
What I did to make it "easier", is buy a Dorman 800-159 double bead line fuel kit; which fit the factory fittings on one end and can be used with 3/8" and 5/16" line (the beads act like good barbs). I made them up to the sending unit with short (4" or so) pieces of hose and good stainless clamps. Set the tank and hook up the plug and vent; thread the hard steel lines across the cross member and now it's simple to hook them up without being over the tank.
Not the best way but I have a bad back and really have no able-bodied help getting the bed off and didn't want to mess with removing the camper shell.
Nic
Santa Fe, Texas
LOL an angle grinder works too..Bed bolts are cheap brotha.. I found that the worst ones to get out are the ones closest to the cab. Had our tractor ready, got the bolts grinded off, then took to em with a pipe wrench and PB blast. Came out like a charm. Tank inspected, out and new one in faster than a lesbian leg fest. Lickedy split son...:redspotdance:
