DRW to SRW?
6.4blackout
Seabrook,TX
I have an 08 F350 DRW and I was looking in to converting it to a SRW and my question is what all would be needed to do the conversion, I understand that the 2008-2010 has a different bolt pattern and some mods to the back will have to be done.
B.Warning
NE Missouri
05+ dually trucks use 8x200 bolt pattern. Pull the spacer off the front axle and the remaining studs will be 8x170. Find a srw 05+ sterling 10.5 rear axle and slap it in along with a new bed. Sell your old stuff and you'll most likely only be about your time. Or find someone with a srw that wants a dually and swap parts.
i've got an axle out of an 05 complete with brakes and all, no springs. 108k miles on it. pm me if interested.
Buck1
Winchester, IN
I'm interested in a 8x200 dually axle. Pm me what you would like to have out of it.
Sent from my VS985 4G using Tapatalk
HeavyAssault
Middle, VA
Would the 8x170 studs be the correct length to run the OEM wheels?
