DTC Codes
chadc
Akron, Oh
P006B MAP/Exhaust Pressure Correlation
P2263 Turbo/Super Charger Boost System Performance
also sct is picking up codes u0100 and u0115
Anybody know why it is throwing these codes? I am running sct with innovative diesel tunes.
The truck takes forever to warm up, and it pops and blows tons of white blueish smoke when cold, the idle changes to almost a lope idle sometimes and almost sounds like its missing, i have no idea what is going on.
jdgleason
Fort Collins, CO
Are you pulling these codes with the SCT? Sounds like you could have a screwy sensor, but the pop points to hardware (maybe Injectors)
chadc
Akron, Oh
The truck only has 22k on it so I hope its not an injector, it only pops when you go more than half peddle when its cold, im using a scanner my friend has to pull the first 2 codes and the sct is pulling those other 2
The truck is a 2010 f350 with dpf delete, 4in turbo back, afe intake, sct with innovative diesel tunes, and a southbend dd clutch
powerstrokin15
Charleston, WV
check your MAP, EBP, and Barometric pressure. i have a feeling one of those sensors are out.. my EBP sensor went out and it acted the same and pulled the same codes. minus the smoke.
chadc
Akron, Oh
How do i check these? When i bring the MAP and EBP up on the sct the MAP gauge flashes and the red alert light flashes also, im not sure how to check barometric pressure
forcefed6.4ford
Medicine Hat... Again
Yeah. Pull them and give them a quick cleaning. Might get everything working for cheap. If not the sensors need to be replaced.
On edit. When the EB sensor is out, take the tube off as well and make sure there is nothing in that too.
chadc
Akron, Oh
Cleaned the EB sensor it was completely packed full of black soot, im still getting the same readings, but the truck seems completely different its running a hell of a lot better, im just not sure why im getting the same readings
chadc
Akron, Oh
well the popping came back this morning, why does this sensor keep getting plugged up so fast?
