Dyno guesses?
space_heretic
Im going to have my 99 f250 run on the dyno for a pull right after my mustang.Just to see what it makes so its pretty conservative compared to some of you guys.
engine 60k .20 over
38r
stage 2 single shots
DP 80hp econo tune(temporary until i get a 6 pos)
frx
4 inch afe turbo back no muffler
4 inch intake 6637
boost whatever stock 38r's make i haven't cranked it up yet.
Im guessing 400+- and 800ft lbs
4r100
I'll be running on a mustang dyno
my mustang im guessing 450/450
dentexpowerstroke
denton, tx
What actual size injectors. Stage 2 isn't a size, that could be anywhere from 160/100 all the way up to a 200/100 have to be a little more specific
What size injector? What nozzle? Stg 2 doesnt really tell us anything.
If you go on a dyno that works and doesnt give out "everybody is a winner" dyno results, id say under 400hp. Unless those stage 2's are 175+cc with 80 or 100% nozzles. Im gonna say in that case you could.wring 425ish out of them considering 238/80's are a sub 500hp injector...
Chvyrkr
Depending on how old that tune is... The one I had did 4.9 ms of PW @ 3000psi, so, that's enough to empty every variant of a "stage 2" that I can think of.
CSIPSD
Bend, OR
engine 60k .20 over
38r
frx
4 inch intake 6637
4r100
Nozzle size and CC... Kind important...
And a SOI map thats just scary!!! :puke:
Chvyrkr
4.9ms in an economy tune ? What did the fuel vs rpm map look like ?
Yeah, and I have no idea anymore.
The external hard drive I was keeping my data logs on in 09, ish, got knocked off the desk and buuuhbye went a bunch of crap.
I just remember that specific setting in the tune coming up in a thread on PSN about the same timeframe, that ultimately got pretty ugly.
I quit running DP tunes about the same time. But, some time after that I rode in a buddies E99 with DP tunes. Say, '10 or '11... And there was a world of difference in how his truck ran.
space_heretic
No you didn't miss the result's my mustang got a massive oil leak and i just fixed it. I did however find out that the injectors are 160/100's. Once work slows down a bit ill hit the dyno and post results.
Black 02
Woodland, WA
Won't break 400 hp on the econ tune. If you had the 140 hp tune, you'd be low 400's would be my guess.
I always wanted to dyno my 160/100's with the S468. There was zero smoke on the race tune after the turbo was lit. Problem was the motor said F U before I got a chance. :rockon::rockon:
