davey99ps
So here's what I'm up to, I've ordered a 38gal tank that fits in the stock rear location. I'm going to run a sump off of it to simplify things, plus I want to get rid of the dual tank set-up since my front tanks sending unit doesn't work. I've also picked up 2 napa 4770 filter bases.
Now for my questions, 1st, do you guys think dual SD pumps plumbed parallel will be enough for my 238/100s? Also, since im basically redoing my entire fuel system, should I go with larger line than 3/8, or is that plenty? For my return line, should I stick with 5/16, or go larger?
