Early vs late model 7.3 block strength and crankshaft design
Big Bore
9000ft in the CO Rockies
Well here it is. How important is the difference when deciding to build for high HP?
There are, however, two different DI blocks.
The first series design is readily identified by
the lack of solid webbing in the valley up to the
deck of the block (Figure 6). So if you’re looking
down on the deck toward the lifter bores it is
one big opening.
The second series block (c/n 1825849C2) is
used from mid-1998-2004 with serial number
661,974 through 2,030,402. This block received
some structural improvements such as additional
crank counterweight clearance in the lower
crankcase. The visual identifiers are the full
casting separations between each cylinder in the
lifter valley to the block deck (Figure 7).
The direct injection engines get a little more
interesting. Riddle me this: when are three different
crankshafts actually two? When they are
used in the 7.3L DIT engine.
The first two crankshafts are considered the
same product. The only difference between them
is the size of the hole bored into the rod throws.
One (c/n 1818200C1) has 1-1/8˝ bore balance
holes in the rod throws and the other (c/n
1818200C3) has 1˝ bore balance holes drilled in
them. The diameter of the balance hole was
changed for better strength and reliability.
Despite this difference, these cranks are considered
the same and are fully interchangeable
(Figure 9). Use either of these cranks in serial
number engines 501 through 661,973.
The third crank (which is actually
the second design) has no
balance hole in the rod throw at
all and has a slightly different
configured counterweight. This
crank can only be used in the
later block casting (c/n
1825849C1) which has the
clearance (Figure 10). This
crank is used in serial number
Cat_rebel
Rebecca Black took my seat
Couple pics of a 95 vrs a 00 with the heads off to show the upper end webbing (or lack there of) -
(sorry for the large pics, damn photobucket won't let me shrink em)
The 95-
& the 00
Haven't set the cranks side by side but we can check when we around to tearing the 95 down.
Big Bore
Yea I have pics of the blocks and the cranks in a pdf thats in another thread here. But those pics you posted of the blocks show exactly what I'm talking about. Just wondering if that web is a strength issue I should be concerned about.
Homesteader
I was just trying to figure out about this webbing thing. I was just with Jody yesterday and he mentioned that one has webbing in it. We didnt have the time to look in the covers but he said the mid 96 and up should have the webbing,according to Jacob. So the 00 has the webbing? I have 2 blocks on the stand now a 97 and a e99. I planned on using the 97 block. I will check it tomorrow between two blocks. So the block with the webbing is it stronger then the one with out ? In what ways?
Thanks
Big Bore
You may be able to pull a pushrod and put a light down there and see if you can tell. I just pulled a p rod to loan to a buddy the other day and didnt even think to look. In any event I've yet to find any definitive answers on whether it matters. However, It must do something?
One thing occured to me. They changed the crank design at the same time they went to a single mass flywheel. I'm wondering if the crank design change was for vibration reduction.
Homesteader
Well i just looked at both of my blocks and it looks like its got the webbing. When i look down in there i dont see that plate thats in the lifter valley that goes from front to back. Also when i look in there i can see the corners on the webbing.
