EBP ******
MeTo
I just installed my KC-TP38r and ******d the EBPV valve and pedestal cylinder. Can I ****** the sensor and pipe also? Just trying to clean up the engine as much as possible.
Petro
Lincoln Nebraska
Some say the PCM uses the sensor for fueling purposes, but with that being said I've ******d several on both OBS and Super Duty trucks and never had an issue.
MeTo
That's good to know, thanks. Did you need to put a 470 ohm 1 watt resister in the connector for the sensor and valve so codes wouldn't be thrown?
superpsd
Missouri
There are no fueling maps that use the EBP sensor. The automatic trucks pcm do use it for shift strategies. I would rather have it for feed back to check ebp.
