EC/LB Motor Build
Black AOD
Ohio
Turbos Mounted.
Black AOD
Ohio
More views of 2.0 High Powers mounted. 2nd K16 in place. Anodized Dual Fueler pulley in place as well. Elite Fuel Distribution Block mounted too.
Sent from my VS990 using Tapatalk
Black AOD
Ohio
Up-pipes/Downpipe and wastegates in place.
http://s30.postimg.org/lkxo2bik1/16596.jpg
http://s21.postimg.org/jhfpglzdj/16594.jpg
http://s15.postimg.org/85a6nyosr/16595.jpg
http://s30.postimg.org/qm9nhffe9/16601.jpg
Turbo Piping Mounted up, New Fuel Lines in Place.
http://s24.postimg.org/5qmmjzag5/16598.jpg
http://s7.postimg.org/kgt73amej/16599.jpg
http://s18.postimg.org/tkapbvwjd/16603.jpg
http://s16.postimg.org/dt3syidph/16602.jpg
Aeromotive Pump Mounted
http://s10.postimg.org/k2sop9m9l/16600.jpg
Tadd had to overnight us a different hotside VBand clamp. Once that's here, I believe the cab can go down later today. Hope is to have it on the Dyno Friday Morning @ Firepunk.
Black AOD
Ohio
***Update***
Well the hotside Pipe from Elite doesn't fit right, it isn't clearing the radiator/core support at the turndown so the pipe will have to be cut and fit and re-welded and sadly it will need to be stripped and re-powdercoated....Oh well, it is what it is. Pipe is being fit as I type this, other than that, everything is about ready to go for first fire with the new fuel system and 2.0 High Powers.
I'm hoping I see a video of first fire later today. Plan is to get some tunes in it tomorrow if today goes well and have it driven through the weekend and fine tune it the best it can be.
Hoping to take it to Firepunk Next week to slap it on the dyno and fine tune the Twin Wastegates.....And then make a few passes to see what #'s it makes. Hoping to see 850 rwhp.
