efuel basics...
always-strokin
Is efuel straight forward? You need a lift-pump that creates 60-70psi and thats that? Because I see people deleting fuel bowls, running massive cat filters, and an assortment of things depending on the build
backwoodsboy
Merica
pump regulator pre and post pump filtration a bracket to hold it all oil pressure safety switch and various fittings and line to tie it all together. Fairly straightforward.
always-strokin
ah yes, forgot the FPR.
So basically you just need a pump, an fpr and a filter pre-pump to keep tank junk out... and your good to go? That sounds extremely easy.
Binder man
I ran -10 from sump to a jegs Y block. Y block to -6, -6 to 2 superduty fuel pumps, each pump fed one filter, each filter went to it's own head in the front. Out the back of the head to a FPR and into the factory feed for a return.
If I would have used one pump I would have a pre and post filter. Still might add a pre filter before the Y block, but I've got quite a few miles on it and the pumps are still holding in there.
jschildm
Southeast Iowa
I didn't see where this was stated, but in an OBS the fuel bowl should be deleted. They are not built to hold the pressure like a superduty fuel bowl.
always-strokin
:whs: The OBS fuel bowl will crack and leak if you try to put that much pressure through it
if i'm only running 60-70psi through it, I will be running the same exact pressures are the stock mechanical pump. So how would that be too much?
Dieselfever
Beaverlick, KY
The factory pump is a 2 stage, it has a diaphragm that pulls from the tanks and pumps low pressure through the filter housing, which feed the high pressure side of the pump and goes to the heads
always-strokin
I'm a little confused at what your saying? A bypass for one pump to run the both heads?
As in, did you develop a fuel-bypass that will allow the truck to limp around incase your lift-pump dies?
Ohhh that clarifies things. So that throws a curve ball I'd say. I'll need to delete the fuel bowl, and also the f/w sep. Are there fuel bowl delete kits, or can I do that myself?
Dieselfever
Beaverlick, KY
The factory Super Duty fuel pumps have a built in check valve, so if one dies the other will allow you keep driving and not pump fuel back through the feed.
You can build your own, basically have a pre and post pump filter with the pre filter pump being a water separator then run it up and T or Y it off to each head and for a regulator put it on the return side of the heads.
If you didn't want to build a system you can assembly one with parts from Strictly Diesel, which has great kits from what I've seen. Also there are other vendors that can supply you with a compete kit such as Swamps, Diesel Innovations, Beans, etc
always-strokin
Ok good deal man.. appreciate the input.
In an effort save money some have also gotten creative by re-using the existing FPR ... http://powerstrokearmy.com/forums/showthread.php?t=174&highlight=joedaddy
Going to read now.. thank you
