Ege Insight CTS/ EAS Trouble
cw96stroker
Central, Texas
So I just bought my EAS starter kit, pyro, egt, and boost sensor. Instructions say to totally remove the CTS from the vehicle. Hook it up to your computer after opening your MyStyle Program (which I just now installed). Ok so I did that, then it says to click the Customize EAS Devices out of the 3 options that is has there to choose from. It will not let me click on it. I have hit the check for updates button several times and it says my stuff is up to date. So why cant I click the EAS customize option??
Help will be greatly appreciated, I'm sure it is something simple, Thanks in advance.
dsberman94
Pennsylvania
I was gonna say I think you have to plug the was starter lot into the cts. How did you figure it out? I plan to add was shortly as well. Just wondering. Thank
cw96stroker
Central, Texas
I went back over to the shop an plugged it up for a second time, I just messed around on it for about 5 min to make sure it knew everything was hooked up and then came back to the house an it started working.
