egr ****** broke exhaust manifold bolts
ebaby
I'm having some problems I welded nuts on top of the broken bolts
The bolts broke of half way down the drill and tryed EZ out broke it
Of in one then broke a drill bit off in the other one
Can diamond tip drill bits cut through EZ outs or what can I do help
Jacob @ No Limit
Indiana
New manifold is cheap. A good quality drill bit will maybe help you out and some quality easy outs are your best friends. That's one tool you don't skimp on, the ones that save your ass when the worst happens lol
Jacob @ No Limit
Indiana
If you were close to me I'd let you have at it with my 90 deg drill and my Mac drill bits and extractors. You'd be good to go.
UNBROKEN
After you soak it in penetrating oil you're gonna have to grind through the EZ out with a ball head grinding bit for a Dremel or a pencil grinder. Get one a touch larger than the EZ out and make sure you get all of it. Grind straight down until it's all gone then go at it with a better EZ out. It'll take some time. Very tedious process on a bolt that small.
Jacob @ No Limit
Indiana
A small grinding bit is a great idea as well. I just did some weight reduction on the dually in my sig this weekend, and I took my time on them two bolts. Back and forth for about 30 minutes on them. Finally came out all intact though!
pdumont01
CT
Yup the carbide burr sets from snap on on the 90 degree die grinder have gotten a ton out for me.
Sent from my Nexus 6 using Tapatalk
