strokin64l
I have an issue where the egr cooler line goes in to a aluminum inlet port ( where you put the top block off plug for an egr delete ) cracked now either I cracked it pulling the tube out or it was already cracked before I bought it (what I assume) I've been loosing coolant which I thought was leaking around the thermostat housing so I ordered the egr delete for it to do at the same time as fixing the thermostat leak so I did the egr delete and fired it up and it was leaking from that plug so I pulled it out and noticed a Crack I was wondering if there is a replacement price for this it looks removable (from what I can see) I put so jb weld on it and put a lot of rtv sealant on the plug to try and get me buy for alittle until I install my car lift anyone else had an issue like this??
