EGR cooler
southwind1
Has anyone taken out a egr cooler and weld it up and put it back in with good success
Sent from my QTAQZ3 using Tapatalk
Mesa, AZ
I've got it on mine. It works good, and passes emissions as everything is still in place.
Towerguy
Woodstock, GA
The only issue I can think of, if you are doing it to pass emissions it may not work depending on where you live. You will be able to pass visual inspection, but more guys are reporting that the emissions stations are plugging into the truck and checking exhaust flow. If it is welded up there will obviously be no exhaust flow to measure. Depends on where you live.
southwind1
Thank guys appreciate the feedback that will work then we don't have smog here we will be good to go cool.thank guys
