Egr delete nightmare!!!
BOBBYCRAWLEY
I am about to tackle this task myself. I have heard do it when the truck is hot and do it when the truck is cold. Which method is best? I have also heard to tighten the bolts a little then loosen them some and then tighten some and loosen some more and keep doing that till they come out. Sorry to derail the thread.
german154
Central, PA
No worries man...I know I cam say from my nightmare...don't do it cold def heat up the bolts and let them sit for a little
Sent from my DROID RAZR using Tapatalk
BOBBYCRAWLEY
I drove home about 30 miles and when I got home I sprayed them good with penetrating fluid. I gave it about 2 hours and the bolts came right on out. Took at most 20 minutes and that is rounding up and putting up the tools.
german154
Central, PA
Ok started tear down...where are my four bolts located that hold the turbo itself and is it easier to take the uppipe on the passenger off the turbo or off the manifold
Mpoage
OKC, OK
Just take the clamp off of the turbo. There are 2 bolts on each side of the turbo. The pedestal will come out with it.
german154
Central, PA
Ok sounds good...side note...your dad said he was shipping me out a manifold I haven't heard anything you know the status of it by chance
german154
Central, PA
Well got her all back together runs good but chasing a very very small coolank leak..dripping out from the bottom of the fan shroud
Sent while I should be doing something productive
german154
Central, PA
Yea everything went back together nice and smooth no issues...guess if it was easy everyone would do it
Jesse_01
Prince George, BC. Canada
Now you have an idea on how todo a turbo kit lol. I am little bit up in the air if I am sticking with this truck long term or not. So I just blocked my egr. I will need a dually in a year or two.
Sent from my SM-N900W8 using Tapatalk
german154
Central, PA
Yea it was a good project...learnded alot and my dad plabs on keeping for awhile kinda made me want to go get one now im happy with how it turned out
german154
Central, PA
06 Ccsb lariat...but its a stick so im attached to it cause its hard to find. If it was an auto I would be trading it in
devon_344
Opp,Al
What did u end up doing to get it.
I am in the middle of doing one on a buddys truck and just ran into the same problem
german154
Central, PA
I ended up having to pull the exhaust manifold off and put a new one on due to screwing up the hole in the mabifold when I tried drilling it out
Jesse_01
Poopy. There is stuff you can get to rebuild that hole than tap new threads.
