Guys I just put a SCT Livewire and exhaust on my 08 6.4L. When removing the EGT probe behind the DPF the nut broke and I can't remove it. Will it hurt to run the truck without that probe install until tomorrow? Thanks Brad.
With that sensor unplugged the truck will fire up one time and run normal. then when you **** it off and try to fire it back up the next time it won't even crank , ECM will lock you out. I know from experience .
Ooopps!!!! Fired it up and it high idled but ran fine. Turned it off but haven't tried to crank it again. What will I have to do in order to get it back running if it want crank back up?
Your truck will start and run fine all it will do is idle high ~900rpms until you replace that sensor. You can unplug all of them if you want and it will still just idle at 900rpm
