Egt gauge not working.
littleredstroker
where the antelope play
Just like it says. Auto meter gauges less than a month old . Pos and negative wires connected with the ones for trans temp gauge trans temp gauge still works. It's all off the same ground too. Was goin down a dirt road and it started wiggin out. Either reads 1100 degrees or 0 connections are good and wires are clear, no cuts. Any ideas or a way to tell if the gauge itself is bad
Sent from my HTC PH39100 using Tapatalk 2
SouthFlstrokin'
sounds like your sensor took a crap.
check all your wires/connections then try again. if it still does this then its your egt probe
Cota
Autometer replaced my sensor no questions asked when mine went bad.
Give them a call.
Black 02
Woodland, WA
I know you checked your connections. My nuts on the back of the gauge worked loose and made the gauge do exactly what you are saying.
Good Luck!
littleredstroker
The only nuts I haven't checked are the one right off the thermo. I will cut off shrink tubing tomorrow before I go.. was driving down a dirt road when it quit me so loose connection makes more sense
littleredstroker
Ok I have 11 volts to the gauge. Checked two nuts to see it was open and it wasn't. If it was the probe wouldnt it show that it was open ?
