04cr450
Question- switching out the factory egt probe that goes into the block off plate- from what I have read you need to change this probe with a probe in the *** piping. Which probe do you replace it with? I took the first probe(closest to the dp) but the probe sensor is twice as long as the stock probe that I took off the block off plate. IS this the correct probe to replace it with? Thanks
