Electric fans?
swamp_ratt
hudson, wi
As some of you know, I have been working on a dt360 swap in my 95. My biggest issue is that I have no room for any fan between the engine and radiator. I need some advice on what I can get that will fit between my radiator and intercooler. I will be using it as a tow rig and will explore further cooling if necessary. What do ya'all suggest for fans to run between the two and approximately what cfm?
Mark Kovalsky
SE Florida, USA
If you are going to tow heavy you won't find an electric fan that will fit in an engine compartment that can move enough air to cool your truck.
NEVRNF
NW IL
I'll second Mark's statement. I hve run electrics for a while and they do ok as long as the truck is empty and always moving. BUT if i run the A/C it will not cool in stop and go traffic. A/C shuts off and engine temp rises.
