Csilva187
- Joined
- Feb 20, 2013
- Messages
- 562
- Reaction score
- 0
Put it on you chicken LOL
One day I'll get one.
I got 71/59 on my truck and dynoed it weekend before last at the Rudy's event. It made 603/1083 on the first run and blew the bottom boot off. They let me fix it and then only made 549 and 550 hp on the next two pulls. I was expecting more power out of it. I also ran it down the track a few times with a best time of 8.165 1/8th with a 1.748 60'. My truck is lifted 4 inches with 35x12.50 trail grapplers. I ran with the same setup before the tires and new turbos and got an 8.178 with a 1.733 60'.
Rudy's use to typically be a generous dyno...when did this change? Or was it not their in house dyno? That being said those numbers do seem low (on the dyno) even with 35s. Are you positive your truck doesn't have an issue (TC slipping, not maintaing RP, boost leak, etc)?
It was not the one at his shop, it was at an event he held at a drag strip. He also told me it read low as well. I guess I should check and see what my fuel pressure is at WOT. I just put all new riffraff boots on after I blew off that factory one on the dyno.
If it wasn't the one in his shop, then it probably was reading low if that is what others were saying.
