elite raw power compounds
ncollins64
winchester springs, tn
Appears to be a high power 62 vgt and a max power x 88 atmo. Maybe someone can confirm. Don't know anyone running them but Eriks truck has a 62/88 relocated set up that may perform similar.
Jonnydime
It's a cast wheel journal bearing atmo that's the difference. The vgt may have a cast wheel as well.
Dzchey21
wyoming
hard to say, should work well tho, quick spool and big power up top. same turbo that JD is running with a smaller secondary charger.
Fast-6.0
Alamosa, CO
It's a slightly different comp wheel than the High-Powers but it's a 62mm inducer billet wheel in the high pressure and an 88 MFS comp wheel on the atmo. Both turbos journal bearing. Building a set of these now that we will get some dyno numbers on soon.
The atmo is not the same as JD's or Erik's. Both of theirs have better compressors and turbines.
Dzchey21
wyoming
good to know, either way. should make some power
