engine seal kit??
POWERSTROKER1
Somerset, tx
Hey Guys, got a 2000 7.3 with plenty of oil leaks including the oil pan, which i know is just silicon, but while the motor is out I want to replace all gaskets/seals. I found the rebuild kits from ford to have everything I need but it also comes with pistons, rings, etc...
Does anyone make a complete seal kit minus the hard parts??
TIA
broncof250444
Fort Worth/Weatherford, TX
Only seals/gaskets on a 7.3 is front and rear main seal, hpop and headgaskets, then turbo o rings. So I would say just buy the few things you need and couple tubes of the Ford silcone NOT rtv from the auto parts place.
