bluedge8
so I have left my scangauge on eot for a while now and the last couple of times I've driven it, It has reached 270 degrees'. So do you think this could be accurate? or is the sensor bad? if it is getting that hot, would it be safe to assume the oil cooler is plugged? if so can it be cleaned, I've never had one apart. btw the coolant temp is fine. as well as trans temp.
