Excessive speed code
hunter_.b
You guys ever seen this code I was getting ready to bust it off with a friend of mine I left at about 1600 rpm tires broke loose and then tacked to redline and didn't shift, then it shut the truck off immediately. Fired right back up
oxcobra
Abilene Tx
Mine has done it too but not in awhile. It's cause by short burst of tire spin or harsh down shifts. It's basically a communication error between the output speed sensor on the back of the motor and the rear end. Basically they don't agree with each other and call for a shut down to avoid hurting hard parts. Hope that helps and I wouldn't worry about it unless it continues to occur
nannichenni
Same thing happened to mine I just cleared the code and haven't had anything since. Happened when I was spinning on ice also.
