Excursion Shackle Lift
caladash
In A House
Could I please get a quote for some 2 inch Excursion lift shackles for the front please? Excursion is a 2000 four wheel drive. Thank you!
OBSWIZ
Wellington NV
I wouldn't use 2" hangers with the stock springs..just swap V codes that can carry the weight of the diesel unlike the underrated Excursion springs..you will get 2" lift. Plan on shocks..
caladash
In A House
I do have the V coded springs! So I will get the 2 inches of lift with the V coded springs? How do I set the back up to match?
OBSWIZ
Wellington NV
If you add the 2" hangers then you will need a adj track bar, Modded B codes in the rear...plus I'd get the correct shocks and a 30mm rear sway bar..same components I have been selling for 8 years for Excursions..
caladash
In A House
So will the V coded springs up front give me 2 inches over stock? If it does how do I address the rear? I know about the B codes, which blocks under them?
OBSWIZ
Wellington NV
V raise 2".., Modded B codes 2"..stock blocks or no blocks if you don't want level or don't want the 2" hangers etc..but will bottom out once in awhile.
