Exhaust manifolds
02blue
Slidell, LA
At what power level, and how much benefit are the 6.0 manifolds & up pipes over stock, are their better manifolds, I've read the steeds are not perfected, can't fid anything about the RCD mani's ???
powerstrokin15
Charleston, WV
at any power level, the flow is a gain. 6.0 manifolds are cheap, and work great. if you have the cab up, I see no point in not upgrading.
Sent looking at my blown up 6.4
bluedevilslax
Castle Rock, CO
I agree with what has been stated above. The stock manifold are very restrictive and just don't allow for good flow. I have not heard anything on RCD manifolds and as well have read the disappointing reviews to steeds. Depending on the power level depends but my opinion would be just 6.0 manifolds because there are a lot of powerful builds running those.
But if you got the cab up might as well do them while you are in there.
Breaking Habits
Mapleton, Illinois
Idle
Idle-5000 RPM
SoGrand
MN
I have a set of RCD's and will be running the set once i get mine finished. Quality is execllent and i would recommend to anyone!
