Exhaust to tip help
Mulletman
This might be a dumb question but I have a 5 inch straight pipe. And a 8in tip Im wanting to put on with a 5in inlet (its the biggest inlet I can find) but since it doesn't fit over the pipe being the same size how do you get it on? Do you just weld it at the ends and not slide it over or what? Thanks
PDT1081
Bowling Green, OH
Cutting a couple slits in the tailpipe should allow you to collapse it enough that the tip will slip over it. It won't allow you to clamp it, but it'll be a little easier to weld.
