Motostroker
- Joined
- Jun 21, 2012
- Messages
- 1,861
- Reaction score
- 0
Bought this truck off a member on here but I have simply not have the time to complete it. My regular cab project is up for grabs
Looks like a mess butt however every nut, bolt, washer, etc is accounted for. Truck comes with the Trans (which I can throw back together the way it sits. The clutches are smoked) both motors one good short block with 180k, and the other motor is bad. It ate a LPOP. t-case, etc.
I can label each tub aware container with bolts, nuts, from each part of the engine for easy re assembly.
I'll throw in a box of (torqued once) arp studs, it has a live wire, Intake, 4 inch exhaust, etc.
Perfect platform to build something since it's already apart. Go ahead and send injectors out. Stuff like that.
If you know how to swing a wrench this is the perfect opportunity to get into a truck cheap.
Body is 7.5/10.
Will need some brakes and rotors however the front end is relatively fresh and I'll throw a brand new ready lift track bar in with the deal also.
140k on the truck
$6500
Body is 7.5/10.
140k on the truck
$6500
