FICM Programmer
STROKEDOUT
NC
I received my programmer from PHP on Monday.
I connected the programmer to the OBD port and it doesn't power up. I checked the cig lighter fuse and it seems to be fine. My CTS Insight and SCT seem to work when plugged in.
Is there anything else I should look at?
I know they are closed till July 17th so I thought maybe someone here could give me some input.
STROKEDOUT
NC
Mdub- I will give that a try.
F-250- I did remove the relay. I also loaded the stock tune into truck. How do you like FICM tuning?
F-250-Owner
Masontown Pa/Maputo Mozambique
it very nice...... I also got the Looney Wild form Vivian as well.... I kinda thought I had an injector issue... now Im sure I do. It does great with my Innovative tow tune though, I have only tried the atlas 40 though.... only 3 more to try out....
STROKEDOUT
NC
Its the programmer. I connected it to another truck, it didn't power up.
Well no biggie..... I will try to contact PHP next week to see what we can figure out.
F-250- Sucks about the injector issue. Hope its not major.
Bryant- Sounds like a stout setup. Between both tunes.
Mdub707
Mohawk NY
I'm dying to get the gryphon myself... looks like I'm buying AE instead so I can get this pig running.
Kbryant777
Plainfield,IN
It's not bad for stock injectors/turbo. It ran 14.61@ 91 in 95* heat and running 35's on 22" wheels.
F-250-Owner
I changed my oil and added 2 bottles of rev-x..... this thing runs like a scalded dog now... hoping to be able to dyno Vivians Looney Tune Wild and another variation of it she sent me this weekend......
STROKEDOUT
NC
I changed my oil and added 2 bottles of rev-x..... this thing runs like a scalded dog now... hoping to be able to dyno Vivian's Looney Tune Wild and another variation of it she sent me this weekend......
Thats good.
I had a similar issue over the winter. FICM was showing low voltage on cold mornings causing rough starts and idling. Ended up replacing FICM w/ Vivian's 58V FICM and running some RevX.
STROKEDOUT
NC
Well.... I have tried to contact PHP several different ways via, PHP forum, email, PM, and phone. I know they have been busy since the got back from a family reunion.
Should I ship the programmer back with a note of the issue or wait for someone to contact me?
STROKEDOUT
NC
F-250: Job security LOL
Agjake: Just checked the cable, I believe your right. I checked continuity between the OBD plug to the large 8 prong plug. I'm not getting any continuity on 3 of the 8 prongs.
  • FICM pro cable.pdf
BullsEye
F-250 Owner : I read something earlier saying that Vivians tunes do not work well with PHP FICM tune. I could be wrong but I almost completely positive I did saw that. You might check into that before you take the time to pull your injectors and spend the money on something that might be a tuning issue.
F-250-Owner
there was an injector issue before Vivians tuning and the PHP FICM tuner... I only run my Innovative Tow Tune with the Hercules tune.... she mentioned to me that her tunes would run good with the 40 or 80, just not the higher ones.....
