FICM wiring harness
Zmann
the last time this was discussed i believe the van harness was mentioned
but i don't think anyone did the swap ,, someone could sell a relocation kit but it looks like the real problem is the internal components and cold solder joints ..
consider the improved heatsink of the bulletproof unit
SICKS LITER
Salem, NH
i have a bunch of ficm harnesses with broken connectors laying around, you could probably use one to extend your harness but it would be alot of work.
a bullet proof FICM should be showing up here tomorrow or tuesday, i will take pictures
Mdub707
Mohawk NY
I don't see heat being the major issue. Last time this was discussed I seem to remember everyone agreeing there was no real benefit to doing this.
yamaha6927
Gloucester VA
well just replaced the FICM last night and its running great but that damn harness connect is causing some occassional issues its not snapping in all the way. im just happy truck is running again for now ill work on that harness after i find the short in the system that is causing me to blow fuses for tailights/dashlights.
Zmann
u can buy the replacement connector and transfer all the wires
Mdub707
Mohawk NY
are the snaps broke or are you just having trouble getting them clipped? You have to kind of rock it back and forth to seat them really good. I can never "hear" my big one clip, but the two smaller ones I can. PITA.
yamaha6927
Gloucester VA
I check the harness its clicked in fine everytime I drive and hit bump or any hill my water in fuel light comes on as well as glow plug light also before when it gave me the problem I lost taillights ad dashlights it keeps blowing fuze is there a connection? Codes showing are P2290, P2614, P2617, P0000 any help would be greatly appreciated this is my only vehicle
Mdub707
Mohawk NY
P2290 - ICP too low
P2614 - cam position sensor
P2617 - crankshaft position sensor
Typically the cam and crank sensors are falsely thrown when you crank a lot and the truck doesn't start, but it can be linked to some of the wiring feeding the FICM. I bet the wire harness has some issues.
You should take the time to read through this document here: http://www.fordtechservice.dealerconnection.com/vdirs/subsites/diag/6.0L_FICM_Guide.pdf
It will talk about the codes you have and probably pin point the areas for you to check over. Page 15 would be a good area to read a couple times. It would be nice if you had a scanner and could monitor FICM SYNC while driving, and see what happens when your problem arises.
yamaha6927
Gloucester VA
well luckily it went away since i was last on here but will continue research so i can be prepared for when it happens again i appreciate the help. i currently have a livewire tuner you think that could read while driving? im pretty new to this and trying to learn as much as possible. unfortunately due to tuner left in truck while it was down screen is fried it comes up for initial turn on then can barely see anything
Big Angry Hillbilly
Suspect FICM harness chafed on valve cover/stud/FICM bracket, etc. worse on 03-04 models. Possible on all years of F series.
