96OBS
Okay guys I put a flatbed on my 96 f250. Well I done my best to re do the filler neck so it would fill right. Well I took and cut a hole on the bed and ran the cap on top of the bed. I took and cut the outer metal tube a little exposing the inner little rubber tube. I just hooked it to the original spot where you put the cap on. Well now I've got a water in fuel light and finally figured out I cut the vent tube and water is getting in through it and need to re do it. So can I just buy some hose and clamp it back to the rest of the metal vent to to replace it? And where can I run my filler neck where it won't be on top of the bed? I don't want all the problems of filling the tank but I've gotta do something....
