Finishing Steve's Abandoned Project
HOOV3R
Central PA
we learned, that if grinding, a sheet does not stop sparks, and the burn marks associated with grinding.
especially on windows.
a sheet to lean the sheet of plywood against was out solution.
throwing that out there.
That isn't just a sheet, it's an actual light weight welding blanket.
HOOV3R
Central PA
I need beer, the fuel cell will get finished tomorrow. Got the cam bearings and cam in the block also.
Wish the rear crossmember would have just been riveted in like the 6.0s
Tree Trimmer
Ahhhh. Never heard of one.
Get them at a welding shop?
It sounds like a obvious question, but I asked my local guy for something like that and he looked at me with the wtf you talking bout look we are all familiar with
Sent from my XT1055 using Tapatalk
HOOV3R
Central PA
MSC I believe, had it for a few years.
swinky
Eastern, Nc
Lookin good. Are the bumpstops as close to the axle as they look?
Sent from my HTC One using Tapatalk
JDub
Hooper, Utah
C-notch and 4-link with an airbag on the back side of the axle
Sent from my DROID BIONIC using Tapatalk
HOOV3R
Central PA
Well, long story short, the block is still at the machine shop. Originally, the machine shop inspected the block and said it would be fine with just a slight hone job. Now, after honing it a little, a defect was found in one of the bores requiring it to go to .020" over at the least. Still waiting to hear what the final bore ends up being so I can get pistons ordered.
Breaking Habits
Mapleton, Illinois
I have 500 0.020 & 0.030 over pistons on the shelf. Give me a call when you figure it out and I'll take care or you buddy!
