First start after injectors and delete
06-sixoh
Bakersfield
Sorry for the typo. I meant 30 ft lbs for the injectors.
I used an 18mm socket on an half inch breaker bar. Latched onto the bolts inside the pulley bolted to the harmonic balancer. It was a pretty easy crank. I turned it CW, and only got two turns on the pulley CCW. I tried to turn over with the alternator, but the belt eventually slipped. They are brand new belts.
Does anybody have any recommendations on a starter? Im looking at BPD's alternator, mainly because i know BPD makes pretty a pretty good product, and its only $30 more than O'Reilly's. Not sure if its any better. I might just buy local so i can have it same day. Im taking a break on this thing. Its burning me out for sure.
Like i said before, im going to try and keep this thread updated for future "searchers". Thanks for all the advice gents.
Stroked777
Casper, Wyoming
Ok so the engine is turning over that means it's not hydro locked. When you do start it it could smoke a bit both white and black. My next step would be to check over connections. Like under the ficm. You said it was just did a build so check and make sure all your grounds are attached too
06-sixoh
Bakersfield
Ok, update.
Three starters later, i got the truck started. Built oil psi on the second crank, and fired on the third.
Everything seems to be tunning fine, as far as I can tell. But one thing. It wont build boost. It starts to at 3000 rpm, but thats it. Previous owner had run a red wire off the turbo harness, im guessing some kind of smoke switch maybe. I took that off, and using a connector, spliced the wites together. Thats the only thing ive did.
I finally blew the hose connected to the turbo on a hard acceleration. Any thoughts? Ive got my guy coming over monday to take a look at this thing with his IDS
Stroked777
Casper, Wyoming
Those boots blowing are common. Just clean them up real well or get new ones, the lack of boost can be from a boost Leak. I would check for leaks. I believe dieselsite sells both a leak detector kit and new boots
06-sixoh
Bakersfield
Yea, im not really worried about the boots. Im worried about the boost issue. I will track down some leaks tomorrow.
04cr450
harford county, maryland
I have bpd's starter and is really a nice piece... but.. its not a bpd's starter, it is a nsa starter, google the starter and u can save just about $100 by purchasing it somewhere else other than bpd lol as far as an alternator, nothing beats dc power.
06-sixoh
Bakersfield
Alright. So we found a break in the harness going to the vgt solenoid. Got that fixed. Once we fixed that, we tried to start the truck, and it wouldnt build oil psi. *face palm* So we are letting it cool off so we can get it fired up and see where i am loosing oil psi. Dummy plugs, stand pipes and IPR are brand new. Im really hoping I dont have an HPOP issue.
06-sixoh
Bakersfield
I drove it for maybe a mile. I had the IDS hooked up to it, and it wasnt reading any injectors psi.
Im so burned out on this truck, im considering selling as is. I dont really want to put anymore money into. How much do you guys think a broke 6.0 would go for? 😂
04stroker
Sarasota-Bradenton, Florida
You have to do a fair amount of driving or hard accelerations to work the air out of the system after start. Until you do that you si have long sometimes 30 second starts since air is still present. So put it through a couple good cranking cycles if you haven't already and see if it starts.
06-sixoh
Bakersfield
Im not sure if you guys understand. I have an IDS hooked up to the truck. There is no injector PSI. No oil PSI.
04stroker
I do understand exactly what you mean did you give it a good couple 30 second cranking cycles and watch it and it never came up at all? Or did you just crank 5-10 seconds and stop?
not having icp can be air in the system. is there any low pressure oil?
also-if you unplug the icp sensor does anything change?
06-sixoh
Bakersfield
I unplugged the ICP and nothing changed. I killed the batteries twice after it ran for a minute. They were long cranks for sure.
