Flo Pro 5" Install on 2013 F250 CCSB
wreedps
I am trying to install a Flo Pro 5" system on a 2013 F250 CCSB and it seems to be a little long and doesn't line up very well with the hangars.
What is the trick? Is there one, or do I just need to cut a little off to make it line up and fit right?
Kbuterbaugh04
On my 6.0 they included a pipe that was long enough for cclb and the instructions said for short beds, to cut I think 12" off iirc. But we had to mock it up on the truck to make sure the hangars lined up before cutting.
Hope this helps.
Sent from my SAMSUNG-SM-G870A using Tapatalk
uga33
Cartersville, GA
Should be no cutting on our trucks using a Flo-Pro. You may have been shorted the adapter for the shortbed trucks.
stevens6.7
Houston
You should have 2 extra pieces of pipe left over. I have a 13 with this setup and everything lined up perfectly.
Edit: Added a picture of the 2 pieces I had leftover.
Downey
Lock Haven PA
I'm assuming your removing your ***? If so easiest way I have found is to support your transmission with a jack. Then removes stock exhaust. Then start installing new exhaust from front to back. Get everything losly hanging. Then once all installed tighten front to back
